Hey all, first off, I will explain the basics of my recently completed sub project. I have a 15” TC Sounds TC-3000 with twin 15” TC-VMP’s (passive radiators) tuned to 16 Hz in a 4.2 cubic foot enclosure. The TC-3k is a quad 1.4 ohm DCR (2 ohm Nom) voicecoil driver. After wiring my TC-3k in all series to net 5.6 ohms DCR (8ish Nom.) I have found that I have to turn the amp up 3/4 of the way and boost my LFE output to +4 (to bring the voltage up to what the EP2500 likes) in order to get the good healthy bass I like. The amp, a Behringer EP2500 is bridged as well.
Here is my question. Can I wire the sub to a series/parallel configuration and run the amp bridged? That would end up being 1.4 ohms DCR (2ish ohms Nom) without killing the amp. I don't like the idea of having the amp up that high.
The other idea is to pair 2 voice coils together in parallel and then drive each pair off a non-bridged channel. I am thinking that running a pair of VC’s at 1200 watts at 4 ohms each would be better than running the entire series of 4 VC’s at 8 ohms at the same power. I am not sure which route to go but I have heard the EP2500 is a beast and it seems I am just scratching the surface. In short, given the goofy wiring configurations of this driver, I am looking to get more power from the amp without melting it at some silly low impedance. Thanks again everyone.
