Sub advice: my trusty Velodyne HGS-18 died
G
Gussboy
Well my trusty 12 yr old Velodyne HGS-18 has recently died on me and I am looking for a replacement. My newer dedicated media room is only a 1400 CU FT (14'x11'x9') room so I am thinking that I just do not need a new sub as large as the HGS-18 I had prior. My primary listening is for movies and I do not listen to music at all in this room. I love heavy bass soundtracks and watch alot of action movies.
Budget is $2,000 max but I would like to stay well under this if possible. So far the SVS SB13-Ultra has caught my attention and am wondering what else I should consider given my budget and room specs. Would the SB13-Ultra feel like a downgrade from my older 18" Velodyne?
For reference the rest of my HT gear is as follows:
Velodyne HGS-18 (dead subwoofer)
Frequency Response: 15Hz - 120Hz
Woofer: 18"
Amp: Class D, 1250 watts RMS, 3000 watts peak
AV RECEIVER: Denon 3808 CI
Power output: 130 WPC / 7-channel
SPEAKERS:
Martin Logan Scripts (fronts)
Frequency Response: 70–20,000 Hz
Martin Logan Theater (center)
Frequency Response: 70–22,000 Hz
Polk Audio (surround rears)
ImcLoud
ImcLoud
If i had a $2000 budget I would go with
VTF-15H DualDrive Package
Or if I felt like building something I would go with
2- Dayton Audio 15" Ultimax Subwoofer and Cabinet Package 300-7097
and power them with a crown xls 2500, by the time you buy all the stuff you need, like spike feet, fill, paint, glue you will probably be under $1000 and have a hard time beating them for twice that...
I have all the materials to do mine minus the amp, but Im having mine veneered so Im waiting for the veneer to come from brazil {don't ask}...
ImcLoud
ImcLoud
For HT use and this budget and room size pair of PC12-nsd should be more than enough
and if you feel building I'd recommend this monster:
http://forums.audioholics.com/forums/diy-corner-tips-techniques/86486-sealed-18-dayton-rss460ho-4-4-cu-ft-kit-best-thing-since-sliced-bread.html
VTF-15H is great sub, but I would never EVER call it compact by any means - it's huge !
Yeah, they definitely aren't small but make a ton of bass.. I was just stating what I would do, actually I would probably go with the uls15 dual drive for a little more money... But I have a vtf2 in a room larger than the op's and it is more than enough... so for aruond $600 Im sure the VTF2 would make him happy... But why not go with as much as you can afford :)
BoredSysAdmin
BoredSysAdmin
dual uls-15 - now that's a sweet combo !
theJman
theJman
It's not reasonable to assume a unit with a 13.5" driver will be able to effectively compete with one that had an 18" driver, especially when the latter was well regarded. The SB13 Ultra is a very nice subwoofer, and you would probably be quite pleased with it, but some performance variation is to be expected.
Along with the units mentioned thus far a few others to consider are the Rythmik F15HP and FV15HP, which I suspect would give the Velodyne a run for it's money (if not exceed it's capabilities). Another potential option is the PowerSound Audio XS30. That one would surely exceed the Velodyne.
1
16hz lover
If you DIY, the Stereo Integrity 18" has more displacement than the Dayton and displacement is what subwoofers are all about.
shadyJ
Speaker of the House
Staff member
It doesn't have a lot more displacement. Both drivers have been measured, the Dayton is very close in performance. Dayton here and SI here.
BoredSysAdmin
BoredSysAdmin
you beat me to it, I was about to say same thing. It look like SI has a bit higher output, but at expense of higher THD
Jeff R.
Problem with SI is that they are always sold out of their subs......I waited 4 + months for them to get them back in stock......I eventually gave up and I ordered a pair of the 15" ultimax diy setups that I am currently working on.
