Stupid speaker wire question
reubenv2
Just wanted to know if going to an 18 gauge speaker wire instead of the 16 the manufacturer suggests is going to significantly affect my set up. The rear channels on my set up are between 50and 60 ft. runs. Got a whole new system and wiring up in a new room. Always used 16 gauge before, but wondering if it was really nesessary.
P.S. Love this site. Learning a lot. Keep up the good work.
JVC
JVC
Yes.........for long runs like that, you want to go larger, not smaller. For that kind of run (50'-60'), you'll want to use at least a 14 ga. wire, but 12 ga. would be even better.
You can get good, reasonably price speaker wire, at Lowe's or Home Depot, on 100' spools.
Good luck!
apatel25314
apatel25314
really i would just go with 12 gauge wire, also you will probably want it cl2 rated for in wall installation , ps it seems price is an issue, i would go with bluejeans, but if that is too much i would get some from monoprice
