Streaming TV Shows via kodi to media player
3db
3db
Has anyone ever tried to stream movies using Kodi (XBMC renamed) from an Android device to a smart tv or media player?
BoredSysAdmin
BoredSysAdmin
Just to be clear : from kodi or to Kodi? And it shouldn't be complicated aa dlna is very much supported both aa target and source
3db
3db
To clarify, from Kodi running on the tablet to my Western Digital since I do not have a smart TV.
BoredSysAdmin
BoredSysAdmin
While it is possible, it's not easy to do. Like Lulimet mentioned - im also big fan of fire stick. Only con is no hd audio bitstreaming or vc1 support
3db
3db
I figured it out. The WD needed a firmware upgrade which included miracast which was needed in order for the tablet to see the WD. I watched S1E1 of Agents of Shields via Kodi using window mirroring to by display in the home Theater. :)
Lulimet
Lulimet
Wow, I never thought that WD would support miracast. That is cool of them to add that.
