Hello,
I have a Panasonic SA-XR55 receiver and I want to get a stereo signal on my surroundspeakers.
When I play a CD the music is heard from the Front speakers (A-speaker), but I want it also on mij 2 surrouns speakers.
I thougt when I make an extra cable between the output of the Frontspeaker B (additional pair of frontspeakeroutput) I van easily switch the B speakers to go on together with teh other front speakers (Speaker A).
But when I turn the volume higher suddenly the receiver displays "overload" and the receiver is turned out.
Als when I listen to a DTS 5.1 film and push the speaker B button to go out. It also gives an overload when I set the volume louder.
How is that possible?
Maybe the only solution is an audioswitch.
Then I have to connect the left and right surroundspeaker output into the switch (+ and -) ann d the output from the Front speaker B to the switch.
The switch has to got two outputs for the 2 surroundspeakers.
So when I listen to a CD in stereo I switch, so the only output to the surroundspeaker will be the output from the Front speakers B of the receiver .
When I listen to a DTS 5.1 film I switch again and it will cut off the Frontspeaker B stream an pass through the signal from the receiveroutput for surround speakers.
I'll hope you folks understand me
Kind regards,
Machiel Mulder
