Use the A channel and run the speaker wires from the receiver to the sub and then from the sub to the main speakers.
Most A+B speaker switches are wired in parallel. If you hooked up the sub to B then you would have to use A+B to hear it but due to the parallel wiring the impedance seen by the amplifier will be very low and it probably won't be handle to handle it very well, if at all.
