Stereo Rack, which/where to buy?
L
litmu
I dont have one currently, and need a well-constructed awesome looking (though economical) rack system to put my:
80lbs, Emo XPA-5
30lbs, Marantz AV7005
Blue-ray
VCR
so at least 4 shelves (with 2 very sturdy). Any ideas where I can find one?
walter duque
walter duque
80lbs, Emo XPA-5
Blue-ray
VCR
Check these Salamander - Synergy System out. Very high quality build.
jcl
The Salamander Synergy is a great rack system. I really like the infinitely adjustable shelf height (although the setup can be a bit time consuming).
As stated before they're not cheap.
The other thing is they are often a la carte, so be careful you know what you are ordering.
Oh, and they're not very deep, I think 18" on the regular back. Another 3-4" on the extended back. With your Marantz I'm guessing you'll need the extended back or just leave it off. I found out the hard way, but got a new receiver out of it.
They sell through Amazon and occasionally have good sales.
We also have a BDI AV Stand that is really well made too, just no where near as adjustable.
If cost is an issue try craigslist, especially for the synergy as you could add on later.
