ISSUE: Trying to figure out how to setup my speakers with my current amp if possible
I currently have a Yamaha HTR 5490
Impedance Switch Details:
Switch
position
Speaker
LEFT:
Main
If you use one set of main speakers, the impedance of
each speaker must be 4 Ω or higher.
If you use two sets of main speakers, the impedance of
each speaker must be 8 Ω or higher.
Center
The impedance must be 6 Ω or higher.
Rear Center
Rear
The impedance of each speaker must be 6 Ω or higher.
RIGHT:
Main
each speaker must be 16 Ω or higher.
[Canada model only]
Right
The impedance of each speaker must be 8 Ω or higher.
Center
The impedance must be 8 Ω or higher.
Rear Center
Rear
I have 4 Polk Audio M10 - quoted at 8 ohms per speaker although Ohms Meter puts the speakers closer to 4 Ohms
I have 2 JBL Loft 40 quoted at 8 Ohms per speaker
and One Polk Audio CSR Center Channel Speaker quoted at 8 ohms although Ohms Meter puts speakers to 4.8 Ohms
For some reason I couldn't post the specs of my amp or speakers
thanks
Nick
