Hey STRONGBADF1, would you possibly consider just manually turning the unit on/off, or is that not even a possibility? You probably won't have much luck, but you might try turning up the sub preamp level, and turning down the sub's gain to compensate. (I've heard that sometimes helps subs more easily trigger on). Anyhoo, sorry.
