Jeff, welcome to Audioholics. Your post raises several questions.
The main issue I see, is your Adcom preamp dates back so far back that I think you should consider replacing it. If I understand correctly (
I read this), it has Dolby Pro-Logic Surround Sound, but nothing more modern such as Dolby Digital or DTS decoding. Those became current sometime in the late 1990s. They will sound significantly better than surround sound via any version of Pro-Logic. DVDs in either of these formats have 5 discrete channels of sound digitally encoded on the disk. In comparison, Pro-Logic takes 2-channel audio and synthesizes a center and rear channels.
DD or DTS are now dated formats as well. They have been superseded the various loss-less digital sound formats found in Blue Ray players. Blue Ray disc players are inexpensive, and will play all older CD and DVD formats as well.
I don't know how much you plan to watch movies with your surround system, but if you do, there will be significantly audible benefits by replacing your preamp with something modern. If you will only listen to 2-channel music, then your preamp will be fine. But if that's the case, why you want a surround sound system?
As far as the speakers go, if you like your L890s, look for a center channel speaker made by JBL that seems to go with the L890s,
such as the LC2. For rear channel speakers, if you plan a surround sound system for movies, I'd suggest something smaller and less expensive. The rear channel content in most movies is significantly less demanding than for the front three channels.
Your amplifier is fine, but I think you might put off decisions about more amps until you have looked into modern AV receivers. I suggest that because you can get an AV receiver with RCA preamp out put jacks that allow you to continue using your amp. That way you can get all the modern audio decoding features, the ability to seamlessly hook up a TV set, and use the receiver as a preamp for those channels where you have outboard amps.
