Stands or Not in my Office?
K
Kleinst
Ok, this one on the lighter side, I have a somewhat modest setup in my office with Advent Prodigy Towers which I bought fairly cheap because the wood matches nicely with the furniture. I realize I can get better speakers but they sound pretty good and again WAF factor in this part of the house. They worked great standing on their own but figured some small stands might get the tweeter closer to ear level. Not sure I like how they look but it's growing on me. Any thoughts from the peanut gallery?
Also, I'm always watching craigslist etc, for a good deal on similar cherry/wood speakers that would go well in here. This would kind of be my trial and error fun room where I can buy things in and out.
Stands for sure. Those actually seem a little low, but better than on the floor.
Mikado463
Mikado463
stands for sure and given their placement you aren't doing any critical listening so save those $$ for your main rig !
K
Kleinst
I agree. Still a little lower than ear level but much closer. This is the room you see to the left when you walk in the front door, so having them a little lower is better from a looks perspective as it's an office not a theater room. But I agree, probably another 4-6 inches higher would be preferable. They are unique speakers in that they are not full towers and longer than bookshelves.
Within about 1ft of ear level still works, especially for non-critical listening. Certain speakers may be more picky, your room and seating position factor in, but in general it works and it just depends on how important it is to you. As long as it sounds good to you :)
Do the built-in stands have a bit of an angle to them? Hard to tell in the photos....
K
Kleinst
No, those are level. It puts the tweeter about 6 inches below my ear when I sit. Not too bad
It was 8 inches lower as those are 8 inch stands
They are the Rockville stands and I got some on Ebay for $37 (vs $60 on Amazon) so I figured what the heck. Worst case I just don't use them. But I think I'll keep them.
Ah, was thinking they were specifically matched to the Advents (thinking how some of the largish bookshelf/smaller floor standers had sometimes matching stands, angled up a bit to aim more at your ears).
F
fmw
Do whatever it takes to point the tweeters at your head.
