Stands for Klipsch RS400B
K
KlipshDevil
Can anyone advise suitable stand for Klipsch RS400B surround speakers? Don't want to mount on the wall so a stand is at least one option. Needs to be at least 30 inches tall. I have seen some from Sanus but speaker doesn't attach to the stand but just sits on top. Not stable enough for my needs. Kids might bump and knock onto the floor. Am I being too paranoid here? Have others found these stands to be stable and secure enough? Any help with this would be appreciated...
WaynePflughaupt
WaynePflughaupt
With a drill and a few screws you can attach any speaker to any stand. That’s what I did with the Paradigm Atoms I have in my bedroom system. I just shot a pair of #8 sheetrock screws through the speaker stand’s plate into the bottom of the speaker. Since both are probably MDF, be sure and pre-drill the stand plate a bit larger than the screw you’re using, and also drill a pilot hole into the speaker.
Regards,
Wayne A. Pflughaupt
