Stands for Athena b2's ?!
HurleyBC
I would love to buy these speakers to match my f1's and c1 center but i cannot find any stands that are capable of carrying 14 lbs speakers. The stands have to be at least 4 ft high to play above the rear of the couch. I have a 7.1 system. The problem everywhere I have looked the stands i find are like 2 feet tall. I know athena makes stands for them but I looked everywhere and can't find them. Wall mounting isnt an option. Thanks
N
nm2285
If you wouldnt mind building your own, it's pretty cheap and they will be solid. Just need some MDF (or other fairly thick/dense material) for top and base, an all thread rod, and some PVC pipe. Then you can sand fill them and customize the looks. Search diy speaker stand and you'll see some designs.
