Spikes can not decouple energy --- they do exactly the opposite. This was an audiophile myth that started years ago with some claiming that a spike acts like a diode(Why such a crazy idea? Maybe because the profile of a spike on a surface resembles the schematic symbol?). If you wish to decouple energy, you will need to use something such as a low compliance foam base(these are sold by pro music distributors for this very purpose) or make some sort of suspension base that has a resonant frequency that is below the bandwidth you want to decouple. If you have thick carpet, placing a large size flat base on the carpet and subsequently placing the speaker on this base may help decouple energy. The layer of carpet acts as a spring/damper system -- though probably not optimized -- may be somewhat effective depending on the mass of the speaker, size of the base and density of the carpet.
Decoupling is not going to reduce a wide band of energy, but if the floor structure has a primary resonance within the band that is decoupled, that narrow peak(of one noted type sound) will be decreased by decoupling the speaker from the floor. In some cases, decoupling may also enhance sound quality if the resonant peak was severe enough to audibly affect music in the listening room.
-Chris
