I see Marantz no longer appears to support this receiver as it doesnt appear on their site. I sure could use some help regarding the menu set-up as I recently lost the subwoofer output when I play cd's only. Its fine when I play DVD movies and listen to 5.1 DD via the cable box. I have the TV hooked up via component video and with one audio path via digital co-ax ex the DVDV player for movies & CD"S. I run HDMI ex the cable box to the TV HDMI input with an alternate audio path via digital co-ax ex the cable box as well. I was asked to set all my speakers to "small" with the sub to"yes" and set the crossover to 60 to 80 H and try it again. Other than the speaker set up menu, I'm unable to find the cross over set-up on the menu and oddly enough the sub speaker menu set-up is frozen on the "yes" position. As well, how does one restore the original settings on the receiver as another possible means to correct the problem? Sure would appreciate a good "wire" on this. Thx
