Duel fronts question
Hello,
I'm new to this forum and this is my first post. I'd appreciate any guidance on the following speaker setup I'm planning to impliment. I ordered and just received two Snell in-wall AMC 770’s for the left and right fronts and an AMC 870 for the center. I somehow accidentally ordered an extra 870 which I’d like to use if it makes sense. FYI - The 870's are 4 ohm and the 770's are 8 ohm. Both speaker types use identical speakers/tweeters with the 870 having two 6 1/2" base drivers vs only one for the 770.
I plan to connect the two 770’s in parallel to make the load effectively 4 ohms to match the impidence of the 870’s and use the two 770’s as a single center and the two 870’s as the L & R. I plan to put the two parallel connected 770's below the plasma with the tweeters next to each other.
Thanks..., I appreciate all comments/recommendations etc… I hope to be a contributor to this forum going forward where I have specific knowledge and experience.
