Assuming you have the signal strength, you most certainly can split your cable line. All you need is a 75 ohm splitter.
you can run it to your cable box and to your HDTV with no problem, but one generally needs to feed the cable to a cable modem before it can be fed to a router or a computer.
kearin said:
My Cable Internet Router is in my office with a seperate cable connecting running to it, it is in turn hooked to my 4port wireless router.
But, methinks what you refer to as your "Cable Internet Router" is in reality a cable modem, which, like old-fashioned telephone modems, takes a signal and makes it readable to a "real" computer hub/router. You can't run a cable signal directly to your computer.
As long as you maintain that modem to hub rlationship you'll be fine. I'd say wireless may be the best way to go. That way, where you locate the modem and hub become less of a concern.
Should you decide to split the signal for use by the 'puter and blow for another cable modem, you most likely will need order it from your service provider, which costs $$ every month.
