Splitting Center channel to two
  • Thread starter jhing.geronimoshop@gmail.
  • Start date
Is this possible. Can i split the signal of my center channel to two power amp just to accomodate my two center channel speakers? Is this possible?
Avr Receiver Center Channel to Pre-Amp Center Channel then y split to (A)Power Amp Center Channel and (B)Power Amp Center Channel.
Hope somebody can help me about this wild idea. TIA
L
Leemix
Yes you can. But why the double pre amp? (AVR+multichannel pre-amp)
Two center channels can make things less clear.
The ideal center channel speaker is a point source time coherent speaker. The more you deviate from that ideal the poorer speech clarity will be.
shadyJ
Speaker of the House
Staff member
This is a bad idea.
As others mentioned, not a good idea. To do it, make sure the two power amps have high enough input impedance, I would suggest each of the two power amps you intend to use should have input impedance no less than 20 kOhm, preferably much higher.
