Specific Q For Paradigm ADP370 v3 owners
cam
cam
I have long since wondered if the guys at the factory labelled my ADP370 surrounds wrong. There is a sticker stating R and L but how would I know if they got accidently switched. So if you could, could you check the terminals on the back of your ADP's if it is possible. You will notice they are off center and encircled. Are they off center towards the rear while you are at your seated position or are they off center towards your tv. Thanks for any response.
L
lubmar
I do not have them, but the "regular sound" should be played from the spk. facing front and the "fuzy/reverbound sound" should be play from spk. facing back.
cam
cam
I switched them and I can't tell the difference. They actually sound good both ways. I know their is one way that they are supposed to be set.
