Spear Wire Wall Plate & iPod
tgdsilva
I noticed that I have a Speaker Wire Wall Plate (GE Model #: 22752004; search in HomeDepot website with keyword '22752004' to see a picture of it since I cannot include a link here yet) in the living room of the house I purchased. I also noticed there are a set of speakers on the outside of the house (backyard side). I assume they are connected to each other.
Can any speaker wire be used to connect a stereo to this wall plate? Or does it have to be any particular type of speaker wire? Please recommend some type of connectors doesn't make a mess in the living room.
Most importantly, how about connection an iPod to this wall plate? What type of wires/connectos/adpaters do I need since there is no way I know of to attach speaker wires to iPods.
thanks!
MDS
That wall plate looks like it has spring terminals and you press the red and white buttons on it it to open the little silver hole above and insert the wire. The only requirement for speaker wire you'd have is to make sure the gauge of wire you use isn't too thick to fit in the little holes. If you want to stick with that plate, you could terminate your speaker wires with pin connectors and insert the pins into the plate instead of the bare wire.
You could also swap those plates for a wall plate like this: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=261-354 which is what I use in my house. There will be no performance difference but they look nice and you can terminate your speaker wires with banana plugs for easy connection and disconnection.
It's possible the speaker wire in the wall that is connected to the wall plate runs to the speakers on the outside but if the house was pre-wired it is also possible that the speaker wires run to some other location in the living room where there is a Volume Control (or at least space for it if it does not exist yet) and the wires from the VC location actually go to the speakers on the outside.
You can't connect an iPod directly to the speaker wall plate. You connect the iPod to a receiver and speaker wires from the receiver to the wall plate. The intent of speaker wire wall plates is simply to hide long runs of wire behind the walls instead of having it visible on the outside running across the floor or up the walls.
tgdsilva
thank you.
i don't have any volume control in the house. my speakers are 'AudioSource LS200'. i took one of these spearks out and connected to my iPod by using a 3.5mm to RCA connector (cut the RCA end of the cable; connected the wires to the speakers directly) and i was able to hear some music... VERY low volume. my iPod may not have the power required to work these speakers.
i see that i need to get a receiver.
thanks!
