Speakon to bare 12 ga. wire
alexwakelin
Anyone make/sell cables like this? I didn't see anything like this on Monoprice/BJC web sites.
jliedeka
jliedeka
You can buy Speakon connectors and make your own. I know Parts Express and probably a lot of other places sell them. If you don't want to do that, you could just buy some Speakon cables and cut one end off.
Jim
alexwakelin
Thanks, know of any how-to's on making my own? I've never dealt with this type of connector before.
Adam
Adam
I did a Google search for "12-gauge speakon cable" and came across a number of hits.
Top hit was these from Musician's Friend, but there were several options.
EDIT: Ahhh, I missed that you want to go to bare wire. Sorry. It would probably be easy to strip one end, though.
Adam
Adam
Here is a cable with a Speakon connector on one end and a banana plug on the other.
Warpdrv
Warpdrv
Here is exactly what you want....
http://www.parts-express.com//pe/showdetl.cfm?Partnumber=092-190
I have used these for all of my subs, they are for larger wires and will work for expanding with 4 connection...
They work great with external amps like QSC or Behringer or what have you..
Make sure you get the screw type, not the solder type... I'm sure you can figure that part out...
Speaker wire from Bluejeans or Monoprice works great with them...
