I think you're right; I believe only Harman does that.
The best measuring speaker to my knowledge is the JBL Pro LSR6325. I do not know what it costs, though.
sean olive in avsforum said that they use jbl 6332 in all their harman reference listening rooms. he also compared the jbl 4328. I quote:
"Yes, you are correct: we chose the LRS 6332 because they have higher SPL capability. Since we are doing our own loudspeaker/ room correction we had no need for the room-mode correction (RMC) built into the 4328p. The 4328p actually has a slightly smoother frequency response and more extended LF response than the 6332. However, with the four subwoofers and our own auto-equalization, this was not an issue for us."
Thanks for the links. I also enjoyed ur journey to find the perfect speaker (although not all cause the thread is too large already).
I try to read all harman studies (toole, olive, welti, etc.) available on the net although I doubt I understand all of them. Aside from that I read all sean olive posts, earl geddes posts, patrick hart posts, and wmax posts, david rich reviews, d. b. keele reviews, the audio critic, linkwitz website. So I am heavily influenced by what they say. In fact my most recent audio purchase is a sony 7506 due to what wmax said about them.
My current speakers are usher x-719 for fronts and energy c3 for surrounds with an adire audio tempest 15 122l sealed sub with a behringer feedback destroyer. I probably wouldnt have bought the usher x-719 if I were to buy now but damn they look good!
I started this thread so it would make it simpler for people to find out which speakers have the best measurements at different price levels. However, I do not have the technical ability and "know how" to confidently interpret loudspeaker measurements or even rank them at different price levels.
Thus I waited for posts. However to get the ball rolling I would probably just list the speakers that to me have the best measurements according to what I have read and remembered. Once again I apologize that I will not attempt to interpret measurements cause I am not technically proficient and would not like to provide erroneous comments.
1. Infinity Primus 360, 362 - numerous posts about this with measurements on avsforum and audioholics.
2. Infinity Intermezzo 4.1t - from the audio critic
3. B&W Matrix 803 series 2 - from the audio critic
4. Infinity Interlude Il 40 - from the audio critic
5. Waveform Mach 7 - from the audio critic
6. Linkwitz Orion - from the audio critic and linkwitz website
7. Gedlee speakers - from diy audio and gedlee website
8. JBL LSR 4300 series - from jbl pro website spec sheet
9. JBL LSR 6300 series - from jbl pro website spec sheet
10. Legend Acoustics speakers with deqx - from legend acoustics website (reviews with measurements are linked there).
11. NHT xd - from soundstage and stereophile
12. energy c3 - from soundstage
13. infinity beta 40 - from sensible sound
14. yg acoustics - from soundstage
15. revel concerta f12 and ultima salon 2 - from soundstage
16. axiom audio m80 v2 - from soundstage
17. paradigm reference signature s1 and s8 - from soundstage
18. psb platinum m2 and t6 - from soundstage
With regard to double blind listening tests, how I wish harman would publish preference ratings even just among the harman brand loudspeakers in controlled double-blind tests.
Sean Olive said and I quote:
"Originally Posted by theshade View Post
Is it possible to know preference ratings among the harman brand loudspeakers in controlled double-blind tests so it would be easier to choose where we set our own point of diminishing returns based on our different budgets.
Sean Olive answers:
I would have to convince our marketing department to release this information. In addition, we would have to include a specification that captures the maximum SPL output capability for each product so you know whether or not the loudspeaker meets your application requirements.
At the present time, I am trying to convince marketing to publish the comprehensive anechoic loudspeaker measurements that I've shown you, and which CEA and CEDIA are considering to adopt. JBL Pro already publishes these measurements for their products."
I really hope that CEA and CEDIA adopts this as it would be a great help to us consumers who want the most bang for the buck performance.
