Speakers suggestions needed for Yammy rx-v661
Hamtaro
Hi everyone ! I need some suggestions for a Yamaha RX-v661 receiver. Basically looking to spend around 500-600$, it will be in a largish living room, bonus points for durability against small children. :p
Any help would be appreciated. :D
bilgirami
How many speakers are you looking to buy, you can start with two good ones and then keep adding as funds become available? What is your room size. I just wrote about Axioms in the thread titled 'Help a gurl out again please' in the same forum. The M60s I have go as low as 37Hz. Sound is realy cleans and crisp. These sell for $970 a pair but you dont need a seperate sub unless you are really big on bass. Are you planning on using the speakers mainly for music or movies. For music, the axioms would be more than sufficient. There are other option in this price range but size of the room etc. will matter. If you living room is 'largish' bookshelf may not be a good option.
jcPanny
jcPanny
HT Speakers
Consider starting with a nice pair of bookshelf speaker or a 2.1 system in your budget. Otherwise you will be limited to HTIB type speaker systems in that price range.
