SPAZZ2500
I really don't have a price range when it comes to speakers. I am new in that department. I usually bought systems with the speakers included and did not care much for it or how they worked, now I do care about the sound I listen to. I listen to R&B and Rock. I want good front speakers for the cd music along with a sub that matches for 2.1 sound. Then I want a good 5.1 package which makles movies very exciting. Any suggestions.
jaxvon
jaxvon
Is there any kind of maximum? There are some people on this board that can drop $20k on speakers without trouble, so saying there isn't a price range isn't too helpful.
But scolding aside, I'd like to help you out.
markw
I really think you should specify a maximum dollar figure if you want to be taken seriously.
mike c
mike c
B&W 800D
or the top of the line
NAUTILUS (the one that looks like a shell)
hehe
jaxvon
jaxvon
You shouldn't spam the forum. You've posted two threads and multiple posts within the threads with the same question. Just one should work!
SPAZZ2500
SOrry
I did not try tp spam the form but the browser spazzed out. I do have a price range and it is $1500.00. Any suggestions now?
jcPanny
jcPanny
Speaker suggestions
Check out the new SVS 5.1 speaker system for about $900. Should be great for movies.
If you want to max out your budget, consider the Axiom Audio M22ti fronts, VP100 Center, and QS8 Surrounds. Add a 10" sub from SVS or HSU. This setup should be great for music and movies.
If you want to blast R&B party music, then look at floorstander's for the mains.
rikmeister
rikmeister
what size room do you have. what receiver or amp are you going to use.
have you listened to any speakers that you like. also you could look at 3000.00 speakers on audigon.com you can save as much as 50% there on demo or used.
