If you are looking for new speakers, the PSB's get great reviews and solid feedback here. I like the specs on the T55's, except I would have thought they weighed a little more. I had no idea they were that affordable. The Polks can be a little harsh with the wrong amp, I agree. Paired with a Denon really helps. Just finished watching National Treasure in DD, and wouldn't trade them for anything.
PSB Image T55 Tower
FREQUENCY RANGE (Anechoic Chamber)
On Axis @ 0° ±3dB 32-23,000Hz
On Axis @ 0° ±1.5dB 45-20,000Hz
Off Axis @ 30° ±1.5dB 45-10,000Hz
LF Cutoff -10dB 28Hz
SENSITIVITY (1W (2.83V) @ 1m, IEC-filtered Pink Noise, C-weighted)
Anechoic Chamber 91dB
Typical Listening Room 93dB
IMPEDANCE
Nominal 6 Ohms
Minimum 4 Ohms
INPUT POWER (RMS, Clipping <10% Time)
Recommended 10-175 Watts
Program 125 Watts
Dynamic Peak 250 Watts
ACOUSTIC DESIGN
Tweeter (Nominal) 1" (25mm)
Aluminium Dome with Ferrofluid
Woofer (Nominal) 2 x 6 1/2" (165mm)
Injection Molded Metalized Polypropylene Cone,
Rubber Surround
Crossover 2,500Hz, B3; 500Hz, LR4
Internal Volume 1.56 cu ft (43.7 liter)
Design Type Bass Reflex
2 x 2" Front Port Video Shielded
SIZE (W x H x D) 8 1/2 x 36 x 14 15/16"
216 x 914 x 379mm
Feet add 1" (25mm)
WEIGHT
Net 42lb (19.1kg)/each
Shipping 51lb (23.2kg)/each
FINISH Black Ash or Maple
FEATURES
Dual, 5-way Gold-plated
Binding Posts
Bi-wireable/Bi-ampable
Feet/stabilizers with
Adjustable Spikes and Rubber Levelers
US MSRP $899/pair
