I
Isade
If I were looking to buy speakers, between the Klipsch rf-82II or Polk Audio TSI-400, which set should I go with?
Any opinions?
KenM10759
KenM10759
Any opinions?
What are you going to use them for? Will it be just music, just home theater, or a combination of the two?
Choices of speakers depends upon your application, the space, your listening distance and volume levels, what you power them with, and so much more. What led you down to consider just those two? Is there a budget?
I
Isade
It's an overall choice for music/ movies. Budget would be $1500 let's say.
What got me asking is a friend of mine is comparing his Sony str-dn1080 receiver with the Polks to my setup which is Yamaha rx-v1083 with klipsch.
He prefers his setup and rips on my setup.
KenM10759
KenM10759
OK then. Since I don't know anything else, I suggest you pick whichever one you like for looks since you can probably afford either one. They're both OK speakers.
KenM10759
KenM10759
It would probably be best if you got out to some good audio shops and listened to some speakers, then take some home and try them in your space. That's the best thing to do if at all possible.
What you should never do is start buying speakers to get better than another's setup. Often times one can vastly improve the sound quality of what they have just by working on room treatments, placement and calibrating it correctly. Once you have the very best of your current speakers, decide if it's time to audition others. Your ears will be different than your friend's ears. You may find something from Revel, KEF, PSB, Paradigm or a host of others that suit you and your space better than either of those two. For the amount of money at risk, it behooves you to take your time and really be as methodical and objective as possible about upgrading.
Maybe experiment and see how much is the room by swapping setups some day?
2
2channel lover
I wonder why...;)
Seriously...there are other variables that are in play such as the room itself that effect SQ.
Both speakers have a "distinct sound" if you will...meaning they are not trying to be totally transparent...Klipsch has a huge following of owners that love the Klipsch "sound"...maybe even more so than the Polks...not something I would spend much time dwelling on.
KEW
KEW
If you are looking for a definitive statement of which speaker is better, get that out of your head!
Sure someone may make such a statement, but that would be a personal opinion.
As far as I know, these are both competent for what they are.
But don't feel your RF-82ii's are anything to be ashamed of. I have listened to a lot of speakers and felt the Klipsch's (when they were on clearance for $400/each) were the best deal going for HT. They have an immediacy and "impactfulness" that I really appreciate for an action movie and speech intelligibility is very good!
I also feel they are pretty good for music at $800/pr.
I have significantly better (and more expensive) speakers, and these better speakers do, indeed, sound better overall, but the Klipsch are especially good at targeting the things that I want from HT speakers. I think they also hit above their price point for hard charging music like Rock and Heavy Metal. Within that context, I think they are very good speakers!
They would not be my preference for light, soft, jazz, or acoustic type music. They have detail, but there is something about the way the horns cast that detail to your ears that is not ideal as compared to my better speakers.
I find I get the best sound from them if I toe them in so a line projected straight out from the mains crosses at a point 2' in front of my head in the listening position. This can look a bit weird depending on your layout, but it sounds best to my ear (and I have Earl Geddes and a couple of other audio geeks backing me up on that).
If you really want to have a "showdown", the way to do it would be to take your system to his house or have him bring his to yours. That way you are on roughly even footing for room acoustics (ideal would be to have both speakers in the exact same place in the room, but that simply is not practical). Connect both systems to a common source (most DVD players will play CD's and have an HDMI and an optical connection...or RCA's) and use the mute buttons to switch back and forth (first matching the levels - the louder speaker usually sounds better, even if it isn't). If you do this with your favorite music, you and your friend will get a much better sense of what differences exist in the sound of the two speakers. Most likely, yours will sound better to you and his will sound better to him! Bias is alive and well! But if you are honest, you will likely hear things his speakers do better and other things yours do better. It is rare for me to compare two speakers and not hear something that the lesser speaker does better!
zieglj01
zieglj01
Do not weigh too much into his ripping -- while I am not an overall fan of the RF series, if you like them, then you like them, and it is about what floats your boat. I am also not a fan of that Polk series, however if he is happy, then he is happy.
Now if you want to spend some money -- then my two choices are >
Canton Chrono 509.2 -- a real good price -- sold each
https://www.accessories4less.com/make-a-store/item/cantchrono5092dcblka/canton-chrono-509.2-dc-7-3-way-floorstanding-speaker-black-each/1.html
Boston M350 -- use to list for around $2500 a pair -- now on a serious good close out price -- per pair
https://www.amazon.com/Boston-Acoustics-3-Way-Floorstanding-Speaker/dp/B00FJGGJ7I/ref=sr_1_1?ie=UTF8&qid=1513376648&sr=8-1&keywords=boston+m350
Now if you want to get adventerous -- the the BMR Philharmonitors in cherry or piano black will fall into the $1500 range.
http://www.philharmonicaudio.com/BMR Philharmonitor.html
William Lemmerhirt
William Lemmerhirt
Don’t know why your buddy feels all high and mighty? He’s the one with a Sony receiver. IMO your Yamaha is a much nicer avr, and if he likes his rig better, good for him, but his polks aren’t that special either. Choose your gear for you. If you like the rf82’s, I say book em up to the Yamaha and rub your buddies face in that! Or, as mentioned go out and listen to as many speakers as you can. Already some good suggestions here. What I didn’t see clearly is what you have for mains now, and if you’re only shopping for those, or a full Surround system. I’ll throw a nod the the GE Triton seven at 1400 a pr. Here’s a review right from AH. http://www.audioholics.com/tower-speaker-reviews/goldenear-triton-seven-1
Once you hook those up to your Yamaha, you won’t even consider polluting your ears with your buddies rig.
Y
yepimonfire
Any opinions?
Neither.
Klipsch RP-160m’s and a sub will get you a neutral, flat response, high efficiency, and high dynamic range.
The rf-82 II is bright, and many find it harsh for music. While I’m a fan of Polk Audio, their tsi series is simply a prettier version of the monitor II series, it just costs more. Their signature series, tsx or Rti series are a much better value, and are often sold way below msrp.
I
Isade
Thank you all for the opinions. I enjoy my setup, sounds good to me. After listening to them at the store my wife and I were convinced. Yes there are better receivers and speakers but for what it is my wife and I are pleased. My friend is awesome but he truly believes his setup sounds better and thinks its my room setup that is possibly ruining the sound.
