At your pricepoint, your speaker wire should be 14 or 16/2 lamp cord. Not HD or Lowes speaker wire, straight lamp cord. You won't notice a difference with your setup, unless you want to drop down substantially more wampum.
As far as interconnects go, try entry level AR, Dayton, or Signal Cable.
Cheers,
Russ
