Speaker Wire - what to consider
jackdean101
I was planing on buy speaker wire on ebay, but I was suprised by so many different options. I think I need about 100' to run my 5.1 system. What things are there to consider when purchasing? What should I be looking for? To run my front and center I think it will take about 25' each, could something that long effect the quality of sound?
Canton LE series speakers
RX-V661 receiver
Thanks for the help!!
MDS
25 feet is actually considered a short run and 16 gauge wire you can buy at Home Depot will perform just as well as mega-bucks esoteric speaker wire (but may not look as pretty).
Read this page for everything you need to know about speaker wire: http://www.roger-russell.com/wire/wire.htm
majorloser
majorloser
Moderator
If you're planning on running through your walls or ceiling, make sure you use UL-CL2 or CL3 rated cable.
MDS
CL-2/3 and higher (like CM) are fire ratings. Building codes usually require CL2 or higher rated wire for in-wall or in-ceiling installations because normal wire catches fire easily and spreads toxic fumes.
ParadigmDawg
ParadigmDawg
The home depot wire is CL3. I used 500 feet of it.
