Not true and here is why
OK. Now I've read over and over again that every speaker must have the same length wire.
My longest run will be to the in-ceiling speakers. The wire will run at least 25'.
It seems silly to also have 25' length of wire to my fronts which are, at best, only 7 or 8 feet away from the amplifier.
Is this rule of thumb more snake oil?
The only reason to have speaker wire the same length ,besides asthetics, would be to have eactly the same resistance drop, but even that is misleading becuase the resistance of copper wire is very very low in comparison to the rsistance of the speaker.
First : typical case 20 feet 8 ohm speakers ,16 gauge wire
ohms/ft = 0.004016 20ft= 0.08032 ohms
0.8032/ (.08032+8) = 1% resistance lost on wire.
Second: worst case 50 feet 4 ohm , 18 gauge wire
ohms/ft =.006385 50ft= .31925
0.31925/(.31925+4) = 7.3% resistance lost on wire.
No one ever rns worst case and more than like you will be typical case or better.
Bottom line: Don't worry about wire lengths
