Hey guys. I'm pretty new at all this and I have a couple of basic questions. I'm in an apartment and I plan to use some wire molding to run cable to my rear surrounds and also to run a coax for my cable line (the cable connection is on the wrong side of the room
). Is there any problem in running the speaker wire and the coax together in the same piece of wire molding? ...as far as interference and such...
The second question if regarding magnetic shielding on speakers. I have Pioneer speakers (fronts, center, and 2 surrounds). The two fronts and the center are supposed to be shielded (at least the back sticker of the speaker says they are), but I noticed that if I set the center speaker on top of the TV (which is a Toshiba 30' HD CRT), I still see some slight color distortion. Does this mean that the speaker is NOT shielded properly or at all? The speakers are a few years old.
Also, I'm considerin buying a new center channel speaker. If I get a speaker that is truly magnetically shielded, can I set it on top of the CRT without any worries about damaging the CRT over the short or long term? Any advice would be appreciated. Thanks!!
