Hello!
I have had a bit of an issue with my home theater system. To try to explain things best, I will first discuss my setup, then my problem, and what I've done as a workaround to date.
My Setup:
I have a Denon AVR-2112 receiver for my home theater system. I have all components feed to this receiver via HDMI, and 1 HMDI out to my TV. All of my components' (regardless of which I am using) will send the audio signal through HDMI to the receiver and out to my 5.1 speakers (of course depending on the signal.... i.e., if it's a stereo signal, it will output as 2 channel, etc.)
One of my components is a WD TV Live Hub and another is a Logitech Revue. Both do a great job when I play internet media and music [like Pandora] (2 channel), netflix media (5.1 and 2 channel depending on the media), and my home network media from my NAS (2 channel and 5.1 channel depending on the media).
My problem:
I installed two speakers on my back porch. I fed these to my receiver's "Zone 2" speaker leads, which are stereo only. The intent of this is to be able to play media in 2 zones at once (or 1 at once as desired). When I listen to, say, Pandora internet radio, the Zone 2 speakers don't work as my components are configured. An example is, I will have my WD TV Live Hub audio output as "pass-through via HDMI" and not as "stereo", so that when I play movies with 5.1 signals, they'll transmit it. But it seems to confuse the receiver, such that the receiver does not "downmix" the signal to stereo for zone 2, even if it is stereo (since the WD TV Live Hub audio out isn't specifically set to stereo).
Workarounds and ideas to date:
To fix this, I have to go into my WD TV Live Hub settings, change the audio out setting from passthrough to stereo, and reboot my WD TV Live Hub and Receiver to get it to work. This does the trick. But ideally, I shouldn't have to keep switching the settings. Can't the receiver do it?
Another idea I had was to simply add a speaker splitter to my receiver's main front L and R speakers, and add my home theater front L and R speakers as "zone 1" and my back porch speakers as "zone 2". That way I could simply control this type of "stereo" output to 2 zones via the switch, and not have to mess with anything else. However, I am not sure if this will compromise the quality of the signal, and the sound quality of my home theater speakers since it's another "box" the front L and R speaker signals must pass through (I don't particularly care if the back porch speaker quality isn't 'perfect').
Help:
Does anyone have suggestions on what I should do? Will a switch cause any quality loss? Is it recommended? Is it discouraged? What can I do?
Thanks a bunch!
- Nick
