MAJOR REVISION: NOW INCLUDES MINIMUM SUB BUDGETS, WITH WARNING HIGHLIGHTS BASED ON ROOM VOLUME CATEGORIES.  ALSO SPEND FACTORS BETTER ALIGNED WITH IMPORTANCE PERCENTAGES.
PROBLEM STATEMENT:
The forum fields many questions along the lines of;
What speakers should I buy for a $X,XXX budget to build a 5.x.x (or 7.x.x) system."
- In many cases, our advice begins with allocating the specified budget to optimize the desired configuration.
PROPOSED SOLUTION:
To help us more consistently answer the above question across different budgets and configurations, I offer a
Speaker Spend Estimator Tool for your review and comment.
Here is the
link to the spreadsheet on Google Drive.
- For access, PM an email address and I will add you to the permissions list.
REQUEST:
1) Review the
Speaker Spending Estimator Tool  result examples (screenshots) for Small, Medium and Large rooms across three budgets ( $1k, $2k and $4k ) for two system types (Music centric and HT centric) shown in paragraph A) below.
2) Provide feedback on the revised
Spend Factors and
Sub Minimums by Room Size shown below in B) below.
Cheers,
XEagleDriver
A) EXAMPLES:  Since I can not post a Google Sheet program to the Forum, I am providing six program results screenshots using
three room sizes (Small, Medium and Large) across
three Total Speaker Budgets ($1,000, $2,000, and $4,000) for
two system types (Music centric and Movie (HT) centric).
- Low sub budget
Warning Highlights are provided when the Room Size derived minimum sub budget is not met (light red highlights for music systems and orange highlights for Movie (HT) systems.
Of course, the exact calculated values are meant to be used as a general benchmark for speaker type purchase and not as an exact value.
- For example, in the
$1k, Small Room, Music system table shown immediately below,
under the 3.1.0 configuration, the guidance is not to buy a $333 subwoofer, but rather to indicate a sub around the $325 price point is appropriate for purchasing a 3.1.0 configuration with a $1k total speaker budget for a music centric system.  To continue this example, the results also indicate the FL/FR budget would be around $400 and the Center budget around $270.
1) Music system, SMALL Room, $1K Total Speaker Budget
NOTE:  For a SMALL room the low music sub minimum (e.g. $200) does not cause any warning highlights.
2) HT system, SMALL Room, $1K Total Speaker Budget
NOTE:  For a Small room the higher HT sub minimum of $500 causes warning highlights above a 2.1.0 configuration on a $1k total speaker budget.
3) Music system, MEDIUM Room, $1K Total Speaker Budget
NOTE:  For a Medium room even the modest Music sub minimum of $400 causes warning highlights above 2.1.0 configuration on a $1K total speaker budget.
4) Music system, MEDIUM Room, $2K Total Speaker Budget
NOTE:  For a Medium room the increase to a $2K Total Budget clears any warning highlights for a Music system due to the modest $400 sub minimum.
5) HT system, MEDIUM Room, $2K Total Speaker Budget
NOTE:  For a MEDIUM room the HT sub minimum increase to $1000 causes warning highlights above a 2.1.0 configuration for a $2k total speaker budget.
6) Music system, MEDIUM Room, $4K Total Speaker Budget - NOT SHOWN DUE TO NO ISSUES
7) HT system, MEDIUM Room, $4K Total Speaker Budget - NOT SHOWNS DUE TO NO ISSUES
8) Music system, LARGE Room, $4K Total Speaker Budget - NOT SHOWNS DUE TO NO ISSUES
9) HT system, LARGE Room, $4K Total Speaker Budget
NOTE:  For a LARGE room, even with a healthy $4k budget, the increased HT sub minimum of $2000 causes warning highlights above a 2.1.0 configuration.
B) METHODOLOGY:
Assigned each speaker type (FL/FR, Sub, Center, Surround L/R and Atmos) a
Spend Factor value based on my own experience, years of forum reading and participation, and member feedback to this thread.
For each speaker configuration (up to 7.1.4) used the ratio of "
Spend Factor / Type" to "
Configuration Total Spend Factor" (now set to a max total of 6.0 for 5.1.4 or 7.1.4) to allocate the set budget according to the
Importance Percentages.
NOTE:
Importance Percentages are substantially different for Music centric and Movie (HT) centric systems, shown separately below.
Spend Factors for Multi-Channel Music (MC Music) centric systems:
(Updated this graphic as of 15 AUG 2021, 7PM EST)
NOTE:  Please pay particular attention to MC Music and Home Theater Sub budget minimums at bottom of screenshot.  This is new and ripe for constructive feedback.
Spend Factors for Movie (HT) centric systems:
(Added this graphic on 15 AUG 2021, 7PM EST)
NOTE:  Based on member feedback, strong emphasis on higher budgets for Sub(s) and Center, achieved by decreasing budgets for FL/FR and SL/SR speakers.
