That's not really surprising, considering the bulk of the power goes to frequencies handled by the woofs. More importantly, the sensitivity is nearly identical. 1 Db is the standard of "just barely noticeable" difference, and reflects negligible difference in amp power. Because the big ones can take more, I would expect them to get a tad bit louder...remember, doubling power only raises spl by 3 db...and with more robust bass response. That may make all the difference in your system, but you may still be running in the red so to speak. I too would be worried about frying another tweeter, so my first priority would be to pick speakers/amps so that such an outcome is unlikely.
Just for the sake of comparison, compared to the Polks, the Cornwalls you inquired about in another thread would easily create rock festival level volumes, and do it rather cleanly, with far less risk of speaker damage, given the same power you feed the Polks.
edit: sorry, that wasn't you that asked about the old Klipsch, but still, as a counter example to what you use, it hopefully sheds light on your situation.
