I know this picture may be hard to read, but I don't know CAD or how to computer generate the image. Please bare with me.
I have a pretty simple room, but on the outside wall, across from the door, you can see the wall jogs out several feet. I can' t figure out the best place to put my surrounds. The Boxes marked with an "S" are the seats. Behind the front row is riser with my 4- 15" IB system. Here is the problem. If I put the surrounds where the red triangles are, by the number "one" circles, the person sitting on the riser in the back row will have a surround speaker directly in front of the, due to the jog in the foundation, where the asterics are. The front row would have good surround, but that back row would have a two surrounds in front of them about 4-5 feet. Now, if I put the surrounds on the back row, where the blue half-ovals are, I have a few problems there too. My HVAC (not shown) runs the length of the room by the door (upper picture). I have a window on the other side. So if I put the speakers there, one will be above the window, near the ceiling, the other would be about 18" lower right under the HVAC, but still 6- 7 feet above the floor. Good height, but both positions close to the ceiling. I thought the blue might be the best, but wondered also about putting some in-walls in the number one/red position AND some surrounds in the number two blue position as well. So a 9. system. The in-walls in red, number one position would keep the left rear from being so much in front of the left rear seat. At least it wouldn't block the view of the screen too. I know this is a lot to try and sift through, so I appreciate any ideas. Thanks so much.
Roly
