Hi,
I just purchased a 2-channel receiver and a set of Polk bookshelf speakers to use with my TV.  Im surprised how bad the default Samsung speakers are, its so bad its hard to understand what people are saying =\
I have had a Dayton Audio Sub-120 for a while just sitting there, and I figure I might as well use it with these new TV speakers.  But, the receiver I bought doesn't have a sub-out on the back.
After reading around I have come to the understanding that this is precisley what the Speaker Level inputs are for - when you have no Sub out on the receiver.   I dont know what the best way to hook this up is though.
Is it better to hook the sub up in parallel with the speakers or in series?
I know if you hook it up in series (Receiver->Sub->Speakers) it could add some noise to the signal, but does the subwoofer filter the speaker signal at all between its input and output?  ie. does it end up passing the input through a low pass filter (depending on its cutoff frequency) then outputting that to the speakers?
ALSO, if I use the speaker level inputs, if I change the volume on the receiver will it change the volume on the sub?  Im assuming yes...
THanks,
Raman
