speaker khz and db ???
scottyg
It does matter a small amount that the 61 and 62 use the same midrange drivers, because they will be more closely timbre matched. The 81 will outperform the 61 due to the 97dB sensitivity vs 95. +3dB is a 50% increase in sound level and +2dB will still be meaningful, however that does not mean one will sound better than the other based on that alone. Between the 61 and 81, I would go listen to the two and decide which sounds better to you.
N
Nick250
scottyg said:
Can someone break this down really quick and tell me which one of these three speakers would out perform one another an why ? I use a rx-v2600 which is 130 watts per channel and use the klipsch rc-52 center..if it matters the rb-61 and rf-62 have the same size drivers ...my room is 20 x 16 here are the specs
http://www.klipsch.com/products/details/rb-61.aspx
http://www.klipsch.com/products/details/rb-81.aspx
http://www.klipsch.com/products/details/rf-62.aspx
What do you mean by "out perform"?
scottyg
basically which one is supposed to sound better according to specs
N
Nick250
Which one sounds better is based on your own subjective opinion after have listening to them all. Trust your ears, not the specs.
Nick
