G
gzyzwc
Anybody else run into issue's mounting QS4's? I got some blue jean's cable banana plugs and they are a tad to big. . Other than just old fashoined wireing to the posts, any suggestions?
Thanks
markw
All bananas are somewhat long and require space behind the terminals.
If space is tight behind the speaker, I'd suggest you settle for spade lugs.
jhanley
I mounted my QS8's to the wall using the supplied T-bracket.
I used bare wire into the posts and it works great. Being
on the wall I didn't envision moving or disconnecting them.
Ran into the same thing with a customer and some Rocket ELT surrounds. I ended up using spades and it worked fine.
