mtschust said:
The speakers I used before were speakers that came with a cheap mini system and They did not have this problem.
Any help would be apperciated.Thanks
It is not your monster cables for sure, even though you probably paid too much for it
What kind of system are you hooking your speakers up to? If you cross your speaker cable with power cable, you will get a distinct characteristic noise but should not be distortion. Something is going on for sure. Almost sounds like an overload someplace, input signal, amp overload, etc. More info?
