Placebo005 said:
I tried to set my mains to small and selected 'yes' to subwoofer(even tho i dont have one but my speakers have 2 10" subs in em) and it didnt have much bass to it. so i switched it back.
And i dont think i have the option for 80hz - i think the only option i have for x-over is 50, 100,150,200
make sense?
Okay, so set your main speakers to "large", subwoofer to "none", and then, depending on the speakers you have for the other channels, probably you want them set to "small" (unless they also have large woofers in them), and set the crossover frequency just above the - 3 dB lowest frequency that they can do. That is, if your center channel and rear speakers are rated 60-20,000 Hz +/- 3 dB, set the crossover to 100 Hz. If they are rated 40-20,000 Hz +/- 3 dB, set the crossover to 50 Hz; if they are rated 120-20,000 Hz +/- 3 dB, set the crossover to 150 Hz. These, of course, are starting positions, and you may experiment with higher settings, if you wish. However, these will work adequately. The main things to remember are these: You don't want a gap between what your speakers can do and the crossover setting, and you want the setting as low as reasonably possible, because the higher the setting, the more likely you will be able to tell where the subwoofer is by the sound.
So, with a speaker rated at 120-20,000 Hz +/- 3 dB, if you set the crossover to 50 Hz, you would not be getting the proper level of sound between 50 Hz and 120 Hz. That is why you would need to set the crossover to above 120 Hz.
