Now i finally understand.
Setting distances is very important and should be done, its probably covered in a startup guide.
Changing crossovers while it might be easy to do involves a lot of give and take. By asking the speakers to go deeper it strains them a lot more and also the amp itself but this is volume dependant also so if you play at moderate to low volumes you have a lot more room to play with. The woofer is very small in those speakers so a high crossover is needed but you probably have a little room for tweaking. It depends a lot on your room, distance to the speakers/subwoofer and placement. What works in his room might not be the best in yours.
A good idea is to read the manual and see if they mention anything about it but it is probably a good idea to start with the default crossover and use that a while before changing, different is not always better and as i mentioned it is extremly room/placement dependant.
