"My question is, my ASUS motherboard comes with a s/pdif output card. Would using this card to connect to my speakers receive a BETTER quality as oppose to buying a soundcard?"
if you are going to use only spdif connection between the card and speakers, I'd say your ASUS mobo chip will suffice
my speaker already comes with a hardware decoder including all the movies and those types of audio features. thx and ect
As long as you are not heavily into gaming, you will not need 6 channel analog connection to the speakers. So as I said, your Logitek decoder will do the job. (Gamers need analog connection for some special effects that cannot be sent digitally).
Well, actually, I checked Audigy specs, it also decodes DVD Audio... If you have some music in this format, neither mobo audio nor decoder will handle that
some strange reason, my mobo manual says my spdif output supports 5.1 audio but in my driver cmedia program config, it seems to only support 2 channels for spdif
Via spdif output you can send either stereo PCM or 5.1 ac3 signal. If it is 5.1 ac3 stream you are actually bypassing the souncard, all DACs etc, therefore the option for 5.1. is not there. But do not worry, your decoder should receive the signal and decode it properly.
