Speaker cables you use?
  • Thread starter Thread starter dvdpfstr
dvdpfstr
6
0
0
I have just ordered all new speakers from Onix/av123 and will be playing them from wall plates. I haven't ordered any cables yet because I am having a hard time deciding which ones to get from the huge amount of choices. I am wanting to know what you guys use in your set-ups. Specifically which cables, not just where you got them and how pleased you are with them. I am fairly new to the HT/audio addiction and want to order cables so I can have them by the time my speakers and receiver get here. Thanks for any help.
Just go to bluejeanscables.com and spend 30 cents a foot on something if you need inwall installation. Otherwise you can go to home depot and buy a big spool of it. The wire doesn't matter as long as you have the proper gauge for your run length and its made decently after all copper is copper.
I am currently bi-amping my speakers with Carol brand "flexible" 12 gauge wire from Home Depot; it was about $.50 per foot. It is extremely functional. Many people use and recommend this, or similar, for speaker cables.
If you need in-wall CL-2 rated wire, they have that as well, but I have not used it myself.
