Speaker Cable Sleeving.
Billy S
I know this is probably a stupid question, but I was gonna buy some blue jeans speaker cable, and was wanting to dress the cable up with some sleeving. I wasn't sure what that stuff was made out of...nylon, polyester, or whatever else. Has any of you guys done this yourself?
spacedteddybear
This is the place to go: https://www.wirecare.com/index.asp . Sleeving can be made out of a lot of different materials depending on the application. The 'Clean Cut' stuff is the easiest to work with.
Another place would be here: http://www.av-outlet.com/ . Go to cable management on the left menu. I use the stuff from Viablue, but it's a bit more difficult to work with ( and it's a bit more expensive) since the stuff frays a little easier unless you use a hot knife. Free shipping on all purchases over $25.
