Speaker cable recommendions
spike99
OK, So i recently bought B&W CM Series and I'm looking for some good speaker wires. For now, I'm looking for 2 fronts and 1 center. Since I may move in the future, I don't know what living room size I will have so I want to get surround speaker wires some time in the future.
In the mean time, I have bought 14AWG from monoprice with banana plugs. Should get them shortly.
I suppose monoprice cables are good, but I prefer terminated cables done.
I'm currently looking at the below speaker cables:
1. cobalt cable (ultimate speaker cable 10AWG) ~ $150 fronts & center
2. river cable: StarFlex SPX Bi-Wire 2 Banana/4 Banana ~ $360 fronts & center.
I currently use Denon AVR-4308 as a receiver. B&W speakers have 4 speaker connectors. I don't know if it makes a differences to get speaker cables that are bi-wire. I get the feeling that some people say it makes a difference and others not.
Thanks in advance.
its phillip
its phillip
I recommend sticking with the monoprice cable.
WOW, expensive.
Have you looked at BlueJeans cables?
jinjuku
jinjuku
Moderator
Thanks in advance.
Spend that $360 + $150 on a nice amp like Parasound (HCA 1500 or the 3500).
spike99
Maybe off topic, But I don't understand the need of getting a separate AMP... How much of a difference in sound would it be getting a separate AMP ? I thought my Denon 4308CI was a good receiver.
Also, I don't listen to music much, but I would like to try some... Probably would be best to buy CD's but it seems much more convenient to download music instead of having a stack of CD's. Denon has an adapter ADD-11R that I can attach a IPOD touch. In terms of sound quality... would this be good ? I believe when u download songs, it may be compressed but what bit rate is good enough ?
jinjuku
jinjuku
Moderator
Since you didn't state which of the CM series you have...
The CM9 is 89db and 8 ohm but can dip into the 3 ohm territory. 200 watt program (no clipping). You could get a 5 channel amp and bi-amp (bi-wire isn't going to make a difference).
In the end what I am getting at is an amp will make more of an impact as an upgrade than speaker wire.
Your Denon in stereo mode will have enough juice.
spike99
I recently purchased the following B&W CM series
2 CM8's - Fronts
1 CM Center - Center
1 ASW10 -SUB
2 CM1 - Surrounds
Considering that I have receiver DENON 4308CI, Do I really need separate amp ? What do you mean that my Denon will have enough juice in "stereo mode" ?
OK, so you are saying that bi-wire will not make a difference ? In what scenarios would it make a difference ?
jinjuku
jinjuku
Moderator
2 CM8's - Fronts
1 ASW10 -SUB
2 CM1 - Surrounds
Stereo is only 2 channels driven. There is no scenario that bi-wire will make a difference.
Bi-amping could (there is a difference).
As an example:
Parasound makes a dead silent amp.
Crown tends to make amps that have more bass emphasis (a bit more slam)
You could run the mid/highs with the Parasound and the Woofer/s with the Crown.
It's about the best example I can come up with for Bi-Amping outside of going fully active on the cross over and providing amplification for each driver. That is seriously down the rabbit hole and not a bad place to be:D
Z
zumbo
Hook-up the B&W's with the Monoprice and enjoy.
If the Denon runs out of gas, which I doubt, consider an amp. Just know up front, it's gonna sound the same.;) You will just be able to push it a little more.
spike99
Everyone seems to agree to stay with monoprice :)
If having a separate amp may only achieve a higher sound versus better sound... Then it doesn't make sense to get a separate amp for me... Especially since my neighbors won't appreciate the blasting sound.
Z
zumbo
It will give you better sound at higher levels. I am usually the only one at my house that enjoys these levels.
It will sound the same most of the time.
It will take a load off of your receiver, and probably add life to it.
If you constantly find yourself pushing your system to the point the sound flattens-out, instead of livening-up, you probably need an amp.
If your receiver goes into protection mode, shuts down/comes back on, you definitely need an amp. This, along with the above statement, will kill your speakers.
Speakers change sound.
spike99
From your statement, I probably don't need an amp. I really don't have any of the issues you mention.
spike99
By the way, I called Denon tech support for unrelated question and then I asked about bi-amping and it appears that my receiver (Denon AVR-4308CI) is able to bi-amp the fronts (Left & Right). Not sure at this time about center or surrounds...
If the option is there... and without having to buy another amp... Is this recommended ?
Looks to me that it would make a difference to bi-amp versus to bi-wire.
jinjuku
jinjuku
Moderator
Yes it does (I own the same receiver). It's all in the user manual.
spike99
OK.... Thanks, although i don't think i'll benefit for my usage, I'll start looking into this.
BTW, are you using this feature?
