Hi ,
I had a Onkyo 770 HTIB package and the speakers are in the spring-clip format which means I could connect the speaker with bare wires or use the connectors. I chose to use the connector but I have no idea what types of connector I should use to fit in the hole of this spring-clip format.
1.Pin connector:
or
2.Banana connector:
or
3.Flex Pin connectors:
And I was wondering the length of gold plated contacts in #1,#3 pin connectors are too long so that extra gold contacts will expose ,will that
be ok ?
Could anyone suggest me ? Appreciated and thanks beforehand .
