I recently bought two AV amps Sherwood 705i and Yamaha RX-V475. But only the Sherwood amp sounds nice with the speakers I use. I don't know why? So I thought if I posted the power specifications maybe someone can explain why possibly that the Sherwood amp sounded better than the Yamaha when used with my Precision Audio speakers.
PRECISION AUDIO SPEAKERS (CT26):
• Frequency Response: 45Hz-20kHz
• Sensitivity: 90dB
• Nominal Impedance: 8 ohm
• Maximum Amplifier Power: 150 watts
YAMAHA RX-V 475 AMP (produced poor sound with speakers)
• 115W per Channel (8 ohms, 1 kHz, 0.9 % THD, 1 ch driven).
• 80W per Channel (8 ohms, 20 Hz-20 kHz, 0.09 % THD, 2 ch driven).
SHERWOOD 705I AV AMP (Produced good sound with speakers)
• Power Output - Stereo: 80W x 2 (40Hz ~ 20kHz, THD 0.1%) @ 6 Ohm / Stereo Mode.
• Power Output - Surround: 100W x 7 (1kHz, THD 1.0%) @ 6 Ohms, One Channel Driven.
• THD: 0.04%.
• Input Sensitivity/Impedance: 250mv Line (CD, Tape, Video @ 47k Ohm).
• S/N Ratio: 95dB.
• Tone Controls: Bass (100Hz) /- 10dBTreble (100Hz) /- 10dB.
• Frequency Response: Line (CD, Tape, Video) 10-100kHz.
I've heard some Yamaha av amps can be underpowered compared to other brands, so maybe this explains it....but I'd still appreciate it if someone can highlight from the specifications why Sherwood was better sound than Yamaha. Many thanks for reading all this and all help towards improving my knowledge on this issue
Sent from my HTC One_M8 using Tapatalk
