Thanks for the input!
jaxvon said:
You know, you COULD buy a
Carada screen for a few hundred bucks then take it apart and move it with you when you leave the rental place. You can hang it on the wall like a big picture. Of course, I don't know what the money situation looks like to you, and that makes a big difference. The sound treatment is still a great idea though.
My money situation is OK, however, I'm married and we have two unfurnished rooms in the house, and my wife earns twice what I do, so furniture first! (Of course, I think the dining room would be a great theater...who uses their dining room anymore, anyway?)
My money situation will be dramatically better in a couple of years at which point I envision a dedicated theater with projector (ideally projecting onto rear projector screen). Although we could afford one of the Carada screens, I'd prefer not to buy stuff that I will discard in two years. My plan is to slowly upgrade the system to its final composition. (Grabbed the Marantz SR8400 for $460 to make the plunge into surround sound, will likely add a subwoofer next year, then new speakers and projector when location and budget change)
I figure that framing the wall with black DIY absorbers would improve both the audio and visual experience AND the absorbers are removable and could be used in any future theater I put together.
I'm pretty handy with tools so I think I can bang together the absorbers in an afternoon. I'm currently pondering how to rig it to adjust the aspect ratio depending on what we are watching. I'm thinking that the sides and bottom will be fixed and the top panel will be adjustable...
I'll post some pictures later this summer when it's done. I'll graph the room's frequency response before and after the absorbers, too. (Anyone have a link for blank graph paper?)
I appreciate everyone's input!
