Sound Setting help for LG Blu ray player
Soundmaster89
i have a question regarding sound settings for my Blu ray player. I have a LG HR923C connected via HDMI to a Sony HT CT 260H Soundbar now I'm confused about what Settings to chose I have 4 options 1.PCM Stereo 2. PCM Multi Channel audio 3. DTS or 4. Primary Pass Through (which i have selected right now so that the Soundbar does the decoding and nor my player). what do you think would be the appropriate setting?
agarwalro
agarwalro
Primary Pass Through if you want the Sony to do decoding and PCM Multi Channel if you want the player to do it.
Try both and keep whichever sounds better to you. They should be pretty much indistinguishable, but, one never knows.
Soundmaster89
Thank you for the tip i will test it out. Is there a benefit in terms of having the player decoding vs the Soundbar doing the decoding? i ask because when in Primary Pass Through setting sometimes the dialog seems not as clear in some movies.
agarwalro
agarwalro
Looking at both devices online, the Sony only has Optical, Coax and analog. Specifically, no HDMI input. Sorry about that, I just assumed that it did.
The preferable connections are Optical or Coax. You will need the LG player to be send PCM Multi Channel since HD audio cannot be send over these connections (and the Sony cannot decode it anyway).
How do you have it connected now?
Soundmaster89
The Sony Soundbar has HDMI thats why its the HT-CT260(H) the HT-CT260 has no HDMI.
I have my TV and Blu ray connected via HDMI to the Soundbar.
agarwalro
agarwalro
LOL! I was worried there for a sec.
Regarding the dialog not being clear, there could be few causes,
1) Movie soundtrack did not lend itself well to being downmixed to 2.1
2) Sony's Sound Field setting did not work well with soundtrack
3) Soundbar processing circuitry works better with PCM signal
I would say, pick the movie that had unclear dialog and try different Sound Fields. You may find one that works better.
Last but not the least, try the PCM and Pass Through options to see which works better for more movies (across different sound field settings on the Sony) and keep that one. That makes for a lot of permutation combinations to test :).
Soundmaster89
geez i forgot about the sound fields always had it on standard lol i keep you posted on what setting worked. I know now what to do on none World cup days LOL
Soundmaster89
EDIT problem is fixed now did try a possible combinations and found the right one i let the sony do the decoding with the movie sound Field! if i let the player do the decoding + different Sound Fields the difference isn't as great.
