Yes. I recommend you inform us whether they need to be active(built in amplifiers) or passive, size constraints....and budget.
I also recommend that members list their location (it's there in User CP options), so they could be suggested to go down to, eg., Guitar Center on Main St. and listen to XY and Z.
There are many "Pro" type speakers that would compete well with/surpass the SQ of the typical cookie cutter low efficiency, direct radiator "home" type speakers. Though definitely not in the looks/aesthetics department.
Which hopefully you'll be too drunk to notice when singing karaoke
cheers,
AJ
