Been having a problem with this since adding a pair of amplifiers to my setup.
(First off, I'll list the gear involved: Pioneer Elite VSX-92txh receiver, Crown ComTech 400 bridged running center channel, Crown ComTech 1610 running front L and R, hacked apart linelevel cables running signal to euroblock inputs of amps)
The problem is only occuring with the L and R channels, and only while running through the external amp.
Durning quieter scenes, it seems the amp cuts output and it clicks back in when it becomes louder, about a second after it begins. The amp has a power saving feature in the PIP card, but it's not to do with cutting signal or output, it should never cut when powered on, as I understand it.
I'm not positive what to check here, or possible routes of diagnosis at the point.
---Link to ComTech "10" series referrence manual
http://www.crownaudio.com/media/pdf/legacy/101969.pdf
